"Frankenwagon" short and sweet.
Re: "Frankenwagon" short and sweet.
Post by 2wagons1driveway » Sun Mar 26, 2017 5:58 pm
Well I removed the 6" Thuren diesel coils for a set of his 3" Thuren diesel
Soft coils and I am loving the handling increase in the truck. Along with the bed cage and front 3.5's the trucks handling like it's on rails. Also on a side note I did manage to demolish and crack a trail ready bead lock running really low psi and falling into an ice hole at higher speeds then I should have been doing with only 8psi in the tires. Luckily trail ready sent me a new wheel and I am seriously considering running a dual spare set up in the near future cause I go through wheels and tires a lot. Lolol Image as you can see with the trucks bed full of running gear for pre running/ any offroading it sits level now with the front. Image I did leave AlL my drops in for the 6" lift though so the front end has crazy flat drag link and track bar angles etc. which means it has no bump steer and the turning feels very nice and stable. Because all my drops are still in place and I'm running 12" stroke shocks I did lose quite a bit of up travel so at ride height I only have about 5.5-6" of up travel. And about 5" of droop before the coil is too loose to use. Image
Re:
Post by nts007 » Sun Mar 26, 2017 7:00 pm
Holy hell welcome back!!! What caused you to drop the truck to the 3". What did you do to the rear to match. Or do you have super rake!
You must be running half a ton back there to make it level down 3"
Post by 2wagons1driveway » Sun Mar 26, 2017 9:24 pm
nts007 wrote:Holy hell welcome back!!! What caused you to drop the truck to the 3". What did you do to the rear to match. Or do you have super rake!
haha ya well I had some help making the leafs happier at 3"
Heigh ImageImageImage poor leafs got a work out while designing bedcage.
Re:
Post by nts007 » Sun Mar 26, 2017 10:32 pm
Nice lol. My pw leaves have sagged. 1" on the passenger and 2 on the driver
Post by 2wagons1driveway » Mon Mar 27, 2017 7:29 am
nts007 wrote:Nice lol. My pw leaves have sagged. 1" on the passenger and 2 on the driver
ya man my passenger side is still higher then the driver
Post by DamageWagon » Mon Mar 27, 2017 9:32 am
Gas tank, driver and battery all make the drivers side much heavier. Gas tank kills the rear leaf.
Sent from my safe space
Re:
Post by nts007 » Mon Mar 27, 2017 10:50 am
Obviously it couldn't be the driver
Post by 2wagons1driveway » Tue Mar 28, 2017 10:41 am
DamageWagon wrote:Gas tank, driver and battery all make the drivers side much heavier. Gas tank kills the rear leaf.
ya especially with soft lt leafs!
Re:
Post by nts007 » Tue Mar 28, 2017 9:55 pm
You're making me reconsider thuren leaves right now
Post by 2wagons1driveway » Wed Mar 29, 2017 7:01 am
Ya wouldn't be good for you. But his old ones are known to sag new ones aren't half as bad but are still similar squat characteristics then mine
Post by 2wagons1driveway » Sun May 14, 2017 3:22 pm
Some stuff happened
RAM4ROKS
Re:
Post by RAM4ROKS » Tue May 16, 2017 7:42 pm
AWESOME!!!!! Looks like a great setup!
Post by 2wagons1driveway » Sun May 21, 2017 8:55 am
Rebuilt the rr bypass shock today. Was a pain lol and heavy. But finally has pressure and oil again :/ ImageImageImage
