Board index General Member Builds
Re: Boogie wagon take 2
Postby w2dodge » Wed Jan 25, 2017 6:39 pm
:rockon:
w2dodge
Postby Colibri » Thu Jan 26, 2017 12:51 am
You're a bad influence will!!! Thanks w2!
No turbo for me, but heads and cam with long tube headers is in the works :rockon:
Postby Colibri » Thu Jan 26, 2017 1:37 pm
Got the rear cross member notched for clearance at full droop and limit strap tabs burned on. Fire extinguisher mounts made up for the front seats too. Bumpers are getting powder coated today and got the switch plate for the ARB air toggles tacked up.
Postby bstefanic » Thu Jan 26, 2017 10:09 pm
Rig is looking sick man...wish I had even close to your skills.
Hella's behind the grill, locker bypass, BDS Long Arm Kit, Carli Front Diff Cover, Rockcrusher Rear, 37" Interco M16's, ATX Cornice Wheels, DT Pro Fab steering box brace, EBC brake pads, Dynatrac Ball Joints, SY Eliminated Transfer Case, Custom Tom Wood's Rear DS, Kings Arsenal Seat Covers, Dynatrac Free Spin Hubs with Dynalocs
bstefanic
Postby Colibri » Wed Feb 01, 2017 4:49 pm
Thank you sir!
Got the gooseneck and front driveshaft hoop done this weekend, probably going to put the bed back on tomorrow.
Postby Colibri » Fri Feb 03, 2017 10:57 am
Getting the bed ready to put back on! Had to cut for the gooseneck and notch the bed cross members for clearance on the bypass shocks. Normally they're installed upside down but I wanted the shock body up out of the rocks.
Bumpers back from Powdercoating
Gooseneck hole cut!
Notched bed support for bypass reservoir
Other side too
Postby nts007 » Fri Feb 03, 2017 11:24 am
Let me know how it fits with the by pass shocks!! That's one of the things holding me back from those shocks. The upsidedown piggy backs too. Don't like the idea of the body on the bottom. Especially on all the gravel roads. Looking forward to installed pics!!! Looking great!
08 ctd--mini max--thuren 3" coils and shackles--4.56 gears and lockers in pw axles--some lights--afe intake system--bd super b turbo--Banks w/m Injection--Dynatrac Balljoints--bilstein 7100s--37" Nitto trail grapplers--DOR Long arms--Carli track bar--Manual T-case swap--Full PW Under armor--PSC Hydro Assist
Postby Colibri » Fri Feb 03, 2017 4:31 pm
Thank you sir! Beds on and everything appears to have plenty of clearance. I'll get some under bed shots once it's in place and bolted down. Still have to make some support brackets tied to the frame for the rear transferflow toolbox/tank mounts.
Postby RAM4ROKS » Mon Mar 13, 2017 8:45 pm
AWESOME work!!!!! All around a slick build! In particular, I really like the solution on the rear shock setup, I ripped the piggyback reservoir off one of my rear Kings (and very nearly the other as well) on a particularly difficult section of trail on only the second wheeling trip after my suspension install- only three weeks after install. (ended up having to put my stock rear shocks back on and have Carli rebuild my Kings since one was broken off and the other was well on its way to being so) I have actually been running my stock rear shocks since then due to fear of tearing up the Kings again. But now, one of the stock rears is blown so, need to figure out a solution. (I should have a loooooong while (about 56k miles) ago but well... didn't, DOH!!!) I want to run them body up but couldn't come up with a good way of doing so. Your pics have shown me that way though!!!
:cheers:
RAM4ROKS
Postby DamageWagon » Mon Mar 13, 2017 10:09 pm
Morgan, just so you know you can run your rear shocks with the reservoirs over the axle instead of pointed away from the axle. That's how I run my passenger shock. Both shocks have the resi pointed to the rear of the vehicle. Image
Postby RAM4ROKS » Tue Mar 14, 2017 7:46 pm
Thanks for the pic damagewagon! Unfortunately my shocks are a different design (not as cool) and will not fit in that manner. Kinda hard to tell in this pic but, it's the best I've got.
RAM4ROKS
Postby Colibri » Tue Mar 14, 2017 8:51 pm
Thanks ram4rocks! Flipping the shocks isn't all that hard, and it's definitely worth it for those of us that drive by Braille lol.
Postby 2wagons1driveway » Sun Mar 26, 2017 5:50 pm
So you are running limit straps
In the rear eh Tim? I debated running them with mine as well but never ended up doing it. I think my leafs barely allow the travel my shocks can give so I figured eff it. As usual builds looking great! Can't wait to see some action videos etc
Postby Colibri » Mon Jun 19, 2017 1:40 pm
Been a while since an update as I've been busy with other things, but finally getting around to doing some maintenance on the wagon. Repacking the front hubs with NEO synthetic HP800 and changing out the grease in my EMF rod ends to use the same redline cv2 as the carli ball joints.
Disassembled each joint and cleaned out old grease, then cleaned and reinstalled everything with fresh redline cv2. Now I can use 1 grease gun for the whole truck. Takes about 5-10 minutes working at an easy pace per rod end. Very well made stuff. Go Canada eh!
EMF rod end stock dodge taper
Remove set screw and unthread cover
Pull snap ring
Pull internals
Pin races and oring/snapring
Previous
Return to Member Builds
Who is online
Users browsing this forum: Google [Bot] and 1 guest
