Boogie wagon take 2
Re: Boogie wagon take 2
Post by Colibri » Sun Jul 30, 2017 10:05 pm
FirerescuePW wrote:How much longer do we have to wait for the Sickest PW in the West? I only have so much patience for vicarious living!
High praise, thank you! Not much longer. One of these days I Will make it to the rausch creek gtg too!
Post by Colibri » Sun Jul 30, 2017 10:06 pm
TwinStick wrote:
Colibri wrote:Just swapped trasfercase shifter linkage for custom coolguy unit lol
Where did you purchase the "custom coolguy unit" ? Or did you make it yourself ?
:popcorn:
http://forum.powerwagonregistry.org/vie ... f=2&t=4980
Covered it in this thread. Pretty cheap and easy
Post by TwinStick » Mon Jul 31, 2017 2:37 am
:rockon: Thanks.
Traded to 2019 ZR2, Red.
BoldAdventure
Post by BoldAdventure » Mon Jul 31, 2017 9:37 am
I want to see a whole picture of this boogie wagon and not just close ups :p
Post by Colibri » Mon Jul 31, 2017 3:10 pm
MikeKey wrote:I want to see a whole picture of this boogie wagon and not just close ups :p
I'll get you some shots in the wild soon sir!
In the meantime, I finally got around to cutting the bedsides. Not too bad a job really.
Pull brace and splash shield
Tape the line
Enjoy more clearance!
Exhaust cut even with leaf springs
Post by DamageWagon » Mon Jul 31, 2017 3:29 pm
Those aren't Thurens LT leaves are they?
BoldAdventure
Post by BoldAdventure » Mon Jul 31, 2017 3:35 pm
Looking good.
Post by Colibri » Mon Jul 31, 2017 7:25 pm
Thank you sir.
Nope, just standard Carli leafs. Very tempted by the lt thuren springs though
gtomike60
Post by gtomike60 » Mon Jul 31, 2017 8:00 pm
How many gallons does the auxiliary tank hold?
2012,2600 stall CircleD converter,MYoung locker bypass,Dynatrac bjs,Dynatrac no-spin kit w/Dynaloc hubs,Thuren 3" coils,trackbar,shackles and Kings(3"F-2.5"R) shocks,Thuren Alien arms,Synergy steering,Thuren/King steering stabilizer,Carli diff guard,White Knuckle sliders,Thuren bumper,37" Cooper STT Pros,Corsa exhaust
Post by Colibri » Mon Jul 31, 2017 8:25 pm
40 gallons plus a decent sized tool box.
Post by 2wagons1driveway » Tue Nov 13, 2018 8:48 am
Looking good Tim. Always love to see progress on this beast.
Post by olyelr » Tue Nov 13, 2018 1:22 pm
Except there hasnt been progress reports/updates in nearly a year and a half! :lol:
Post by 2wagons1driveway » Tue Nov 13, 2018 4:06 pm
Still better progress then some of the other builds on here...(also mine)
Post by Colibri » Tue Nov 13, 2018 5:09 pm
Thanks Lee! Glad to have you back around here again.
Damn I didn’t realize it’s been so long since I updated. I’m about to swap out my steering gear and ram assist and send some stuff over to Howe to be worked over.
Changing out cylinder diameter and switching back to the 09 box from the mopar big box. Trying to get everything dialed in perfectly for best steering power and response.
I’ll document all that here in a little bit
Post by Reloaderguy » Tue Nov 13, 2018 5:18 pm
Is there a PS pump available that would take out that dead spot when you make quick inputs? It feels like turning the wheel too fast for the steering to keep up. I only feel it when I'm backing up a trailer and making quick corrections.
Post by Colibri » Tue Nov 13, 2018 5:28 pm
At least on the 5.7 you can directly swap in a TC style or CB style pump from PSC Howe KRC or whoever.
I’ve been using a TC pump now with a filtered remote reservoir for a few years. It keeps up no problem. It’s 1000-1500psi and 4.5ish gpm and that’s with a stock sized pulley. If you need a little more oomph at lower engine rpm you can get a slightly underdriven pulley on there to boost performance.
Off the top of my head I want to say the stock pulley diameter is 5.5” and you can get several different diameters smaller than that
Post by Reloaderguy » Tue Nov 13, 2018 5:37 pm
Can the stock pump handle being over-driven? It's only off idle with fast inputs.
Post by DamageWagon » Tue Nov 13, 2018 5:43 pm
Reloaderguy wrote:Can the stock pump handle being over-driven? It's only off idle with fast inputs.
Like any pump, yes. Lifespan goes down and fluid foaming goes up. The Amsoil fluid is very good for not foaming.
The constraint would be how much of a change does the pump see at max engine RPM. If some guys are holding 3000+ RPM while towing for hours, under driving the pulley maybe 20% in a truck that usually lives around 2000rpm shouldn’t be a problem. Lifespan would be diminished but that still might mean 300,000 miles.
Post by Colibri » Tue Nov 13, 2018 5:51 pm
Marcus is right on, stay conservative with your pulley changes and you should be fine. A 10-20% underdriven pump will make a very noticeable difference.
I’d not run atf+4 underdriven though, amsoil or swepco or something similar would be a worthwhile change.
Post by Reloaderguy » Tue Nov 13, 2018 6:40 pm
I'm already running Amsoil. Do you have a part number or source for the pulley? What is the stock size for the 6.4?
Post by Colibri » Tue Nov 13, 2018 7:03 pm
I don’t know off hand for the 6.4, if you can snap a pic of your pump and throw a set of dial calipers on the shaft I can probably point you to the right pulley
Post by DamageWagon » Tue Nov 13, 2018 7:22 pm
Always a good time when guys are wanting to measure shafts.
Post by Colibri » Tue Nov 13, 2018 7:48 pm
OMG and I asked for a picture of his pump too :rofl:
Post by Bill2014 » Tue Nov 13, 2018 8:47 pm
Steered it right into the gutter... :rofl:
Post by olyelr » Tue Nov 13, 2018 9:38 pm
Not really the updates I was looking for fellers :lol:
I know exactly what you are talking about there... happens to me fairly often when I back out of my garage and cut the wheel fast.
