Got some cool shit happening in the next 2-4 months lol sorry to make some of you wait so long! A few of you know my truck already it's a 12' wagon with a pieces together 6" dominator set up from Carli but with Thuren 6" soft coils and some custom soft leafs from British Columbia. There's a few Thuren fab bits on it here and there like axle truss drag link replacement and track bar.
Here's the plan I will be venturing from Edmonton Alberta in the next few months to go to Thuren fab head quarters in bend Oregon to pick up some new stuff. I'm not too ecstatic with the way this dominator set up rides granted I'm not a turbo diesel.... I am pushing through the valving in the front and the rear pretty quickly offroad... On the street it seems to ride pretty firmly. It's more forgiving then the bilsteins I had on there before (2.65 acv's) but it's still not "plush" again that's me not having a Cummins in my truck however I do have a very large 200lb bumper placed further from the front shocks forward which you'd think would give me about as much leverage as a CTD would or very close (within a few hundred lbs I figured)
But non the point. I will be getting new Thuren fab rear shocks. I won't give to many details but their gunna be some pretty cool stuff. Much more capable and tunable than the smooth body dominators. They will be a 3" piston king. With four tube bypasses. And they will have a lot of travel.
I was iffy on my leaf springs and a set of long travel Thuren designed atlas leafs literally dropped into my lap earlier this week that will be for a 6" truck. These are the leafs he uses on his canti trucks so they can support around 18-20" of travel....
The front is going to be very very cool... Again can't say to much. Thuren has done 4" diameter kings before and they work amazing. However I am using Carli radius arms still and I've heard the 4.0's may be damaged because of the natural caster changes the radius arms have given the axle plunger under braking etc..... The fronts may be a 3+ " diameter shock with an external compression adjuster on a finned 2.5" race series king reservoir... They will have dons larger towers he built for the 4.0" shocks but I will have more room with the smaller body ...
What do y'all think? Should on of the knarliest p.wagons to be after this!
"Escalators are never really broken...their just stairs for alittle while... "
Got some cool shit happening ....
- JBM Power Wagon
Re: Got some cool shit happening ....
I think your a little bit nuts, but in a good way!!! Can't wait to see it in action when your all done!
lol gunna be pretty cool and actually not buck me out of the seatJBM Power Wagon wrote:I think your a little bit nuts, but in a good way!!! Can't wait to see it in action when your all done!
Get that all done then come up to my place and drive my commute. I'll ride along. If the coffe done spill then it's working. If it does and the beers are all shaken up......start again
donents007 wrote:Get that all done then come up to my place and drive my commute. I'll ride along. If the coffe done spill then it's working. If it does and the beers are all shaken up......start again
