Rusty's Build - 2008 POWER WAGON RC
Re: Rusty's Build - 2008 POWER WAGON RC
Post by RustyPW » Sun Aug 19, 2018 7:46 pm
Now I know why the welds torn. Found this picture from when I installed the nerf bars. The factory welds only go half way around. :angry:
Post by Bill2014 » Sun Aug 19, 2018 8:27 pm
Wow!
You get the most strength to resist bending from the welds exactly where those stock welds were missing!!!
Post by RustyPW » Sun Aug 19, 2018 9:14 pm
Wow!
No chit! :lol: I welded the chit out of them now. :o
Post by Colibri » Sun Aug 19, 2018 9:52 pm
Nice work rusty! It’s looking great
Post by RustyPW » Sun Aug 19, 2018 10:32 pm
Thanks. My PW needs some TLC right now from all the abuse I have given it over the years. :shock:
Post by RustyPW » Sat Sep 15, 2018 9:54 pm
Rebuilt the front brake calipers on the PowerWagon today, and installed stainless brake lines too. Big difference in pedal feel. Took a whole quart and a half of Dot 4 brake fluid to bleed the front calipers.
The stainless brake lines are from KLM. At +3" over standard 2500.
https://www.klmperformance.com/dodge-ra ... lines.html
On the down side. I went to NAPA to get the rebuild kits. They said that they no longer sell caliper rebuild kits. Just the whole rebuilt caliper. So went to Advanced Auto. Got the kits off of them for $11.78 each. But can't get new pistons. So had to reuse the old Bakelite (plastic) pistons. Have a feeling that you won't be able to buy rebuild kits in the future.
Post by Retired BLM Rig » Sun Sep 16, 2018 12:47 pm
The rebuilders must get their parts from somewhere, just need to find that source.
The current parts swapping culture seems to be making DIY rebuilding a thing of the past. :(
Pit Slave
Post by Pit Slave » Tue Sep 25, 2018 1:58 pm
You can still get pistons.... I just rebuilt my left rear caliper a few months ago for about 10 bucks.... just stick with Carlson....
https://www.rockauto.com/en/catalog/dod ... iston,1724
Pit Slave
Post by Pit Slave » Tue Sep 25, 2018 2:46 pm
Also just a FYI to those in PA......
https://www.instagram.com/p/BoKGLEbA7bw ... ppk0tuv16f
Post by RustyPW » Tue Sep 25, 2018 2:55 pm
NRa aready sent me stuff on it and i sent it in. :rockon: :lockedandloaded:
Post by RustyPW » Tue Sep 25, 2018 2:56 pm
NRA aready sent me stuff on it and i sent it in. :rockon: :lockedandloaded:
Post by RustyPW » Thu Oct 04, 2018 6:22 pm
I had bought the 14,000 lb pul-pal years ago. I had it in the front of bed. Between the tool box and front wall, standing on end. I haven't had the need to use it yet. I had to clean the bed out yesterday. Was hauling patio brick, sand and base. The bed was a mess. So I took it out to check it's condition. Surprised that it has no rust on it. :rockon: The damn thing weights about a 100 lbs. :lol:
AceMan
Site Admin
Site Admin
Post by AceMan » Thu Oct 18, 2018 9:34 am
I'm seeing that on my factory rock rails, too.
Post by RustyPW » Thu Oct 18, 2018 1:10 pm
Get someone to weld that gap up.
Post by TwinStick » Fri Oct 19, 2018 1:10 am
Their thought process was probably to get rid of moisture inside the tubes but i think welding them solid & just drilling some tiny weep hole would be better ?
Post by RustyPW » Fri Oct 19, 2018 3:11 am
That would be the proper way of doing it. The weep hole would have to be about 1/8" diameter. And it would get plugged with mud. :lol:
Post by DamageWagon » Fri Oct 19, 2018 2:26 pm
I have never understood the thought of leaving a tube open to ‘get rid of the moisture inside’. The moisture in the hot air as you’re welding a piece of metal is almost zero. Anything in there is going to oxidize with the surface and then be gone. It’s not going to rust itself from the inside out. On the other hand leaving ends of tubes like rock sliders open just allows them to fill up with mud and water. A small weep hole does more damage than good for drainage - the point of a weep hole is to release pressure during welding so you don’t blow a weld when sealing the unit up
Post by Colibri » Fri Oct 19, 2018 4:02 pm
I’ve never blown a weld, but I imagine a fella would burn his lips doing so
Post by RustyPW » Fri Oct 19, 2018 9:40 pm
It's a welding standard. It's covered in the AWS tech books.
I've seen what happened when there is no weep holes in a closed off pipe. During construction at the power plant. There was a dozen support pipe hangers that they forgot to drill the weep holes into the pipes. When the pipe supports got hot. It started to blow the welds apart. :jawdrop: Because of that. It shut down construction to inspect ALL pipe hanger supports.
Post by DamageWagon » Sat Oct 20, 2018 12:01 am
Rock sliders and recovery gear don’t have steam piping attached to them. This stuff isn’t AWS for pressure application!
Post by RustyPW » Sat Oct 20, 2018 3:27 am
If you are welding to code or not. The same principles apply even if it's not steam piping. It's general practice. Having worked in a couple of fab shops, being a cert welder, boiler maker, welder/fitter, fabricator, blacksmith, and getting my welding engineering degree. I think I should know a thing or two. And forgot a bunch of stuff. :lol:
Post by olyelr » Sat Oct 20, 2018 6:13 am
My wk sliders dont have any weep holes :secret:
Post by RustyPW » Sat Oct 20, 2018 4:23 pm
Neither do mine now. :lol: I was thinking about when I was welding my up. Got lazy. :lol:
Re: Rustys Build 2008 POWER WAGON RC
Post by RustyPW » Thu Nov 15, 2018 10:15 pm
DjRoGah wrote:
Thu Nov 15, 2018 1:46 pm
One of the features of the Power Wagon is sequential numbering.
How would a Power Wagon owner go about finding their number?
It was something Dodge did in '05. Some say thru '08. Leif would know the details of it.
