TD's 2014 Red PW Build Thread
Post by adeluca73 » Fri Aug 12, 2016 3:14 pm
Reloaderguy wrote: Your truck looks awesome. Personally I'd skip the Procal and get a Diablo Sport instead. I don't think there is anything you can do about the TPMS...I've given up on mine.
Thanks man!! Well I am hesitant to spend that kind of $ on a tuner. I will if I have to. However, according to the ProCal literature, it can adjust tire size ( for speedometer), axle ratio (For tranny), & tire pressure setting (for TPMS).
http://www.aev-conversions.com/isheets/ ... ProCal.pdf
Post by adeluca73 » Fri Aug 12, 2016 3:23 pm
olyelr wrote:Looking goooood!
You got $500 for a set of stock duratracs with 27k miles on them?! You done did good! Were they spent or did they have some usable miles left in them?!
Yeah, I let them go for $400. They were actually at 11-12/32", so more than ½ life I guess, more than I thought at nearly 30K miles, and a little chunking on the side lugs from off roading up North, nothing too bad I think.
The solar panel trailers were mobile portable power stations for sale or rent.
Post by adeluca73 » Fri Aug 12, 2016 3:25 pm
RamGentry wrote:quite a transformation for your truck. Great build so far
Thanks man , yours is a true resurrection transformation, I call it the cardiac wagon!!! :rockon:
hammer40
Re: Tires, it happened, and they're 37's...
Post by hammer40 » Sat Aug 13, 2016 10:51 am
Reloaderguy wrote:
adeluca73 wrote:Ok, was able to drop the truck off before the movers showed up this morning. 37" Nitto Ridge Grapplers installed on stock PW wheels w/ 1.5" Truxx level, took less than an hr, had them air to -10% max (50psi Max) so about 45psi all around, measured height is right at 36.66", at 50psi they measured around 36.85", EVIC is freaking out of course, no correction available till AEV sells the ProCal or you buy a spendy programmer/tuner, speedo is off by 5mph according to the speedometer app I installed on my iPhone (PW: 35/Ip: 39, PW: 40/Ip: 45, PW: 45/Ip: 50, PW: 50/Ip: 56), tires ride great, way softer than the Duratracs (still had 12/32" left, so weren't as bad as I thought), and they are definitely quieter, did some full lock turns in the parking lot & no rubbing so far, didn't notice much breaking difference, but I drive like a granny, acceleration took a hit even with 4.88's, MPGs down about .5-1mpg, 1oz,1.5oz, 2.5oz, 4oz were the balance weights, they said the stock tires had over 20ozs glued all around the inside wheel. $1179 OTD installed & balanced, no hazard warranty, After 10 miles, couldn't be happier. Oh and bonus, sold my Duratracs in one day on CL for $125 ea :rockon:
Your truck looks awesome. Personally I'd skip the Procal and get a Dibablo Sport instead. I don't think there is anything you can do about the TPMS...I've given up on mine.
I had my TPMS adjusted down to 50 front and rear at the dealer. No more lights.
Post by adeluca73 » Sat Aug 13, 2016 3:18 pm
Really, when was that? I thought with the new WiTech II, dealers were locked out from making changes to the RFH, which is needed to register new pressures. You can still make a change in the BCM, but w/o RFH assess, the light will still come on. But who really knows. I've spent 3 days vigorously researching this & honestly, I still can't tell if it's something that can be changed as of today. Maybe it could have been changed with WiTech I & the right voodoo dance, but I'm skeptical now. FCA has there collective head in their ass on this.
Post by Reloaderguy » Sat Aug 13, 2016 5:45 pm
The tuner costs almost as much as the Procal but it gives you more control and transmission programming. I need to see some evidence the ProCal can adjust the TPMS because the instructions tell you to take it to the dealer to have the thresholds changed. I presume they mean with a WiTech.
Post by adeluca73 » Sat Aug 13, 2016 7:50 pm
Hey, yes you're correct, you can set the TPMS threshold with a ProCal; however, you need your VIN assigned PIN # which you're supposed to get from the dealer, then you can change the BCM with the ProCal, but I think the RFH still has to be accessed by a WiTech.
Post by Reloaderguy » Sat Aug 13, 2016 10:04 pm
It looks like some of the guys on CF may have cracked the TPMS reset procedure. I'd be interested in a Procal for the fog light programming alone.
Post by adeluca73 » Sun Aug 14, 2016 11:02 am
Reloaderguy wrote:It looks like some of the guys on CF may have cracked the TPMS reset procedure. I'd be interested in a Procal for the fog light programming alone.
....so what is it??? :popcorn:
Post by nts007 » Sun Aug 14, 2016 12:51 pm
Magic....lol. Efi live is a tuner they are using and as far as I know it makes your ecm an open book
Post by Reloaderguy » Sun Aug 14, 2016 1:05 pm
Its the procedure listed in the AEV instructions using currently available diagnostic tools such as Auto Enginuity.
Post by adeluca73 » Sun Aug 14, 2016 1:46 pm
Reloaderguy wrote:Its the procedure listed in the AEV instructions using currently available diagnostic tools such as Auto Enginuity.
Right, which is what I was saying before:
Using the Procal will program the Tire Pressure In ation Value for the vehicle, the vehicle’s information screen may indicate the new programmed value right away, but it will not “take” until this process below is completed:
1. Contact your dealer’s part department about obtaining your vehicle’s PIN, the PIN is a unique 4 digit number based on your vehicle’s VIN.
2. Using WiTech 1 or 2 (desktop application or web interface), access the Radio Frequency Hub (RFH) module.
3. Select the option to Program an Ignition FOBIK (Key).
4. Forward through the menus until you are asked for a PIN Number.
5. Enter that vehicle’s PIN
6. After entering a PIN, the application will ask you if it is correct, select Yes or Continue.
7. Close the Program FOBIK process. Do not continue with programming a key.
8. Return to the main menu of the WiTech program.
9. Access the “Diagnostic Procedures” page.
10. Select the RESET ECU function.
11. Follow the instructions and reset the Radio Frequency Hub (RFH) Module.
12. The Tire Pressure In ation Value will now re ect with actual tire pressure, the vehicle may need to be driven a few miles before the changes are apparent.
Post by Reloaderguy » Sun Aug 14, 2016 2:52 pm
You can't buy the Procal though. I assume AEV has an agreement with FCA that limits who can get a Procal in exchange for the technology necessary to interface vehicle computers.
Post by adeluca73 » Sun Aug 14, 2016 6:56 pm
Reloaderguy wrote:You can't buy the Procal though. I assume AEV has an agreement with FCA that limits who can get a Procal in exchange for the technology necessary to interface vehicle computers.
Exactly...but I've been working this behind the scenes with AEV & trying to get them to sell me one w/o buying their suspension first.
14PowerWaggy
Post by 14PowerWaggy » Mon Aug 15, 2016 2:08 pm
If you make this happen then please let us know... I've tried for almost a year to get the Pro Cal... They just say sorry, not gonna happen without the suspension system...
Latest bits
Post by adeluca73 » Tue Feb 14, 2017 3:31 pm
Pentagon and DC life as it is, doesn't leave a lot of time for truck work, but I've managed to add a few things the past few months, quick summary, nothing special:
1. AMP Research BedStep (Amazon has a $50 rebate running + I bought a "used" one from the Amazon Warehouse, so all said, it cost me just north of $100)
https://www.amazon.com/AMP-Research-753 ... ch+bedstep
2. Factor 55 Hitch link 2.5: rear anchor point for Class V rcvrs, S_y= 18K lb_f, S_ut = 69K lb_f
http://factor55.com/product/hitchlink-2-5/
3. Factor 55 Shorty Strap III : Perfect 3" short strap for hooking to axle tubes when a 30' tow strap isn't required
http://factor55.com/product/shorty-strap-ii-and-iii/
4. Synthetic Winch line is next: 7/16"x 100' Kevlar winch FireLine
http://www.winchline.com/firelines-kevlar-ap/
Post by olyelr » Wed Feb 15, 2017 6:06 am
Those short straps are PERFECT for towing your fellow buddy out by the tie rod :lol:
Post by Bill2014 » Wed Feb 15, 2017 1:11 pm
OMG :excited:
I let the stuck party put the strap on their vehicle - but I check where they put it before I will start pulling...
"um - don't connect it to the bumper that will pull right off"
"Oh! - don't connect it to the tie-rod that will bend and break"
"no way - the exhaust pipe won't work either"
:secret:
Locker Bypass
Post by DamageWagon » Wed Feb 15, 2017 1:45 pm
olyelr wrote:Those short straps are PERFECT for towing your fellow buddy out by the tie rod :lol:
He must be planning a steering upgrade soon [emoji2]
Sent from my safe space
Post by olyelr » Sun Mar 19, 2017 8:46 am
Whats happening Doc? Quit working so stinking much and get us some new updates.
Post by adeluca73 » Tue Apr 18, 2017 12:40 pm
olyelr wrote:Whats happening Doc? Quit working so stinking much and get us some new updates.
Sorry, the damn SecDef has me on a "special project", which I consider a govn't charity, but I digress.
Latest updates, hmm, nothing big other than these three:
1. My PW is getting trashed parked in my driveway in VA, the pollen, the 60yd old trees surround the house, the paint is getting hammered, so this is my short term remedy:
https://www.amazon.com/gp/product/B01KW ... UTF8&psc=1
2. This is for the GSP, it works great to keep his muddy paws off my back seats, and me off him.... :wink:
I really like this product, it is heavy duty and looks good, and is easy to clean up. It's becoming a permanent fixture in the truck.
https://www.amazon.com/gp/product/B00XM ... UTF8&psc=1
3. Another permanent fixture in the truck is this handy hunting and organizing caddy, also sort of keeps my GSP Max-the-dog from jumping on the front seat, sometimes. It takes a bit to get it sized and situated right, but once it is, it's really secure. The top pockets hold quite a bit of gear--binos, shells, dog collars and other bird dog crap, etc. and the gun cases hold a good variety of long guns. My 26" bbl wood stock Remington V3 w/ ext. choke fit, but my 28" Brownelli A5 Ultimate w/ ext. chokes does not fit all the way, and most rifles with scopes will fit, my 7mm RUM and 300RUM do not fit all the way, but close.
https://www.amazon.com/gp/product/B00AR ... UTF8&psc=1
ooohhhh and I forgot...I also some how managed to get a 'bootlegged' AEV ProCal, before AEV locked that sh@t down. There's quite the tedious, but entertaining, thread about the ongoing ProCal saga here http://forum.powerwagonregistry.org/vie ... &start=175 but, aside from the jackassery, the ProCal worked as advertised. I think I am the only one here (?) able to use all the ProCal features, and yes, it has definitely changed the truck's performance. I wouldn't say dramatically, but it definitely returns the truck to at least stock performance, and permits realization of the performance upgrade in adding 4.88's. A very cost friendly mod/enhancement if you're not looking to add custom tunes or custom shift points.
MikeKey
Re: 4.88 Gears arrived
Post by MikeKey » Wed Jun 21, 2017 3:30 pm
adeluca73 wrote:It's a FEDEX Christmas
MOD : 4.88 9.25 front & 11.5 rear AAM R&P swap + complete master installation kits
MFGR : Yukon
Vendor : Randy's Gear
COST : $375 Rear R&P/$330 Rear install kit/$245 Front R&P/$215 front install kit/$60 front & rear lifetime warranty
How the F did you get a $200 discount on the rear R&P and $100 on the front R&P ? I can't find those prices anywhere, including Randys. Hard to imagine a price hike like that occurred in the last year. But maybe. Heck you even got discounts on the install kits. :wtf:
yooper68
Post by yooper68 » Fri Jun 30, 2017 12:49 pm
Hey, MikeKey.
Military discount + Professor discount = very good price!!!
adeluca73 must have about the nicest built PW on this forum )-;
Trucks: 2003 4x4 Dodge 3/4 ton, 1972 4x4 Ford 3/4 ton (factory hi-boy), shopping for new Power Wagon (or may wait for 2020 model? - 75th year special edition?)
Post by adeluca73 » Wed Oct 18, 2017 11:54 pm
MFGR : Yukon
Sorry i’ve been MIA— life. That was a while ago, but whatever i had written was probably exactly off the invoice I received via email after I ordered from Randy’s...spent a lot of time on the phone ensuring I was ordering the the exact right parts...required a few calls to AAM in Michigan to cross-check. The final cost may have been a little higher because I did go back and opt for an AAM rear over the Yukon, which was more, not a lot, less than $50 I think. The install is where the real cost is high. Did you ever go through with the re-gear?
Post by olyelr » Tue Feb 06, 2018 8:02 am
Whats up, Doc?!
After seeing how easy granite crystal scratches AND shows every scratch, the ceramic coating deal has me very intrigued. How is yours holding up? Is it as durable and amazing as they make it out to be?
