2010 Improvements
Re: 2010 Improvements
Post by nts007 » Sat Jun 25, 2016 2:26 pm
Looks much more aggressive lol. I like it. Remember. The all terrains threw small rocks. The hankooks will throw....bigger rocks
Post by Will » Sat Jun 25, 2016 5:03 pm
nts007 wrote:Looks much more aggressive lol. I like it. Remember. The all terrains threw small rocks. The hankooks will throw....bigger rocks
Haha, dude, that last set wasn't my first set of tires. I can tell you already that the Yoko's were better in this Florida sand. These loose grip real easy and don't track well at all in dry sand above 30mph until you get to about 65-70mph and finally start floating on top. They do look alot better and will be better during hunting season in actual mud and clay.
Post by Will » Sat Jun 25, 2016 5:05 pm
I had a sleeper truck, now I notice people looking at it.
Post by nts007 » Sat Jun 25, 2016 11:14 pm
It looks good. I've never played in the Kind of sand you are talking about. My experience is gumbo and dirt fields, gravel, muck and clay and lots of snow and ice
Post by Will » Sun Jun 26, 2016 7:34 am
I have everything down here within a 3 hour radius so they will be tested. Minus rock crawling...
Post by TwinStick » Sun Jun 26, 2016 6:42 pm
:rockon:
Post by 2wagons1driveway » Sun Jun 26, 2016 9:00 pm
Looks real good man real good
Sent from Canada
Post by adeluca73 » Tue Jun 28, 2016 12:03 am
Will wrote:I had a sleeper truck, now I notice people looking at it.
Are those Toyos or Cooper STMaxx
Post by Will » Tue Jun 28, 2016 5:40 am
Neither... Hankook Dynapro MT
Post by Will » Tue Jun 28, 2016 6:09 am
Post by Will » Mon Oct 31, 2016 6:51 am
Was a nice day yesterday so I decided to get out the tape and some Plasti Dip rattle cans....
Post by Will » Mon Oct 31, 2016 6:54 am
Going to actually repaint the fender flares, almost plasti dipped them but I'm thinking more of a permanent fix for them.
Post by olyelr » Mon Oct 31, 2016 12:42 pm
Looks good! I like the black much better than the tan.
Post by Low_Sky » Mon Oct 31, 2016 3:44 pm
Looks good, Will!
Post by Colibri » Mon Oct 31, 2016 8:40 pm
Looks great!
2011TXPowerWagon
Post by 2011TXPowerWagon » Tue May 02, 2017 10:19 am
Will wrote:Going to actually repaint the fender flares, almost plasti dipped them but I'm thinking more of a permanent fix for them.
Did you ever get around to painting the fender flares?
Post by olyelr » Tue Jun 06, 2017 2:14 pm
Just had to check back in for a looksie at that there two tone black and grey rig tuckin' some 37's... I like!
Whats happening, Will, where ya been? Building a house or garage? I miss seeing your humor on the forums.
Post by Will » Tue Jun 13, 2017 8:34 am
Ole PW still looks the same. I have a worn our inner drag link and probably going to replace all of the steering here soon. The damn ABS is still puzzling me. Light comes on and dings all the time but everything seems to be working fine. I ran down a ford ecoboost on a bad muddy road the other day, he couldn't believe I caught and said he thought he was doing some fine driving until I began creeping up on his ass. haha. It was sloppy, soft shit, I told him it takes power to get on top and ride out instead of plowing through it like he was.
Post by Colibri » Tue Jun 13, 2017 9:14 am
Haha nice! Good to have you back around these parts will! Strange about the abs, maybe it's your trucks way of asking you to pull a fuse?
Post by DamageWagon » Tue Jun 13, 2017 3:22 pm
I just found my ABS issue was a loose connector. The wheel speed sensor for the front passenger wheel, above the wheel liner is super sloppy loose. I zip tied it together. Maybe you have something similar? Oh, I couldn't pull the codes even though my ABS light was on. What I found out was that my ABS code only showed up when the engine was running. That might be something to try if you haven't.
Post by Will » Thu Jun 15, 2017 10:49 am
I've checked all the wiring and only thing I can think of is a speed sensor in the wheel bearing assembly. I just haven't made the time to tear back down again. I can tell you the cruise control does not work if the ABS light is on.
Post by Will » Thu Jun 15, 2017 3:54 pm
Well maybe this will get me by on steering for a little while. Full Moog setup with grease zerks, delivered for $248. Image
Post by nts007 » Fri Jun 16, 2017 1:14 am
I've had those moog ones now for a couple years and over 60k miles. Keep em greased. Lasting way better than factory
Post by DamageWagon » Fri Jun 16, 2017 2:45 am
When I greased my new NAPA joints, water came out of the joints. lol. You get what you pay for
Post by Will » Fri Jun 16, 2017 9:50 am
DamageWagon wrote:When I greased my new NAPA joints, water came out of the joints. lol. You get what you pay for
I am leery about it but I have too much play in mine right now and it's a big jump in price for anything else worth getting. Even the OEM was close to $400, my biggest concern is not the joints themselves but the rods. Will they bow under pressure, probably... The OEM has been fine, just the joints have play and can't get just the joints that I know of.
