New Build 2012 Ram 3500 4x4 Diesel Expo/Chase/Tow/Truck
Re: New Build 2012 Ram 3500 4x4 Diesel Expo/Chase/Tow/Truck
Post by 2wagons1driveway » Thu Apr 21, 2016 2:44 pm
Plus that should
Keep your engine way cleaner of soot build up etc.... Great mod
Sent from Canada
gun45boat
Post by gun45boat » Fri Apr 22, 2016 5:48 pm
I heard the same thing about it keeping the internals clean (combustion areas, before and aft) I did notice when I first started driving it after the mod it did blow out some black smoke (not because of the tune, as I run a really clean tune) But I think it was the water/meth cleaning,,,,,if that makes any sense.... The soot smoke stopped after 100 miles or so. I guess it is doing its job. VERY happy with the results..
Post by 2wagons1driveway » Fri Apr 22, 2016 11:59 pm
gun45boat wrote:I heard the same thing about it keeping the internals clean (combustion areas, before and aft) I did notice when I first started driving it after the mod it did blow out some black smoke (not because of the tune, as I run a really clean tune) But I think it was the water/meth cleaning,,,,,if that makes any sense.... The soot smoke stopped after 100 miles or so. I guess it is doing its job. VERY happy with the results..
Hells ya it does make sense they use to decarb engines at about 2000-4000rpm with a water mist into the carb/ throttle body at running temp to steam clean motor!!! Works really well nice done it a few times!
I'm actually looking into this now for supercharging our hemis... No melted pistons because of the cooler air charge and higher octane....
Sent from Canada
