Mr.Smith 2009 Power Wagon Modifications
Mr.Smith
Re: Mr.Smith 2009 Power Wagon Modifications
Post by Mr.Smith » Tue Sep 24, 2013 9:47 pm
Works well in the garage :lol: , I have no "real world" tests, due to the fact that the truck broke & I installed after the fact. I'll let you know once the truck is driving. :secret:
BigRed2007
Post by BigRed2007 » Wed Sep 25, 2013 12:09 am
Do you have stock rims for sale?
Sent from my iPad using Tapatalk HD
Flame Red 07 PW - BIG RED
KE0BZG
WQUY939
Mr.Smith
Post by Mr.Smith » Wed Sep 25, 2013 12:20 am
Do you have some 17" Walker's for trade? :lol: Actually the truck sits on the stock wheels, I used a 2006 Dodge 2500HD wheel only for full size spare...these aluminum wheels are better for spares than the steel wheels, so I replaced it. You can see pictures showing the truck with the stock wheels on it...not sure where you thought they're for sale? I have X1 "regular" non-Power Wagon, polished aluminum,17", Dodge 2500/3500HD, wheel for sale...for the guys that want to ditch the steel spares.
gun45boat
Post by gun45boat » Wed Sep 25, 2013 1:41 pm
Thank you Mr. Smith for the pictures. I am "relieved" :)
Cant you flip those rear shocks the other way, so they wont be "rock hangers" when you wheel the rig?? Aluminum and rocks NEVER get along;)
Mr.Smith
Post by Mr.Smith » Wed Sep 25, 2013 9:46 pm
Dan Torino with Carli said at full compression you'll have interference with the reservoir & the truck bed. Anyone have luck installing the King 2.5 piggy-back reservoir inverted. :idea:
RAM4ROKS
Post by RAM4ROKS » Thu Sep 26, 2013 12:24 am
Looking good, really like the color of your truck!!! Nice build, both in terms of what's done thus far and what's to be done!!!! :rockon:
Mr.Smith
Post by Mr.Smith » Fri Sep 27, 2013 12:47 pm
Thank you Sir...you're a good sport. Looking forward myself to be driving the truck again! :excited:
azracer
Post by azracer » Fri Sep 27, 2013 1:48 pm
To be honest the KING shocks are well known for having soft shafts that are prone to being nicked by rocks and such. I think keeping them inverted is a good idea for longer leak free use. Those shafts don't like road salt either so if mounted shaft down upgrading to the stainless steel shaft would be a must.
Mr.Smith
Post by Mr.Smith » Fri Sep 27, 2013 11:10 pm
Good call...they are stainless shafts. :wink: Mounting the reservoir on the axle side with the shaft up is what saves the seals from debris impact. :idea:
pdavey
Post by pdavey » Sat Sep 28, 2013 10:37 am
Mr.Smith wrote:Good call...they are stainless shafts. :wink: Mounting the reservoir on the axle side with the shaft up is what saves the seals from debris impact. :idea:
I have the piggyback kings on the back as well. I tried 12 ways to Sunday to mount them in the upside down position, but there is no way without modifying the bed rails. So mine are mounted the same way yours are. I wish I had gone with remote resivoirs in the the back for easier installation, but all in all I can't complain about the performance of these shocks. they are great. I also went with the stainless steel shafts on mine.
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
Calvinm119
Post by Calvinm119 » Sun Sep 29, 2013 3:26 pm
Mr.Smith wrote:Here's the Mopar 6 disc cd/navigation & dash bezel, the truck is an SLT basically & came with a single CD/non-navigation setup...
I plan to get this done eventually! Nice! :rockon:
Gone but never forgotten:
2006 Dodge Ram Power Wagon
Mr.Smith
Post by Mr.Smith » Tue Oct 01, 2013 11:59 am
When I bought the truck it was late in 2009, there were not a lot of choices as far as options left on the lots. In fact I went to Salt Lake City,UT to purchase, due to the fact that Colorado did not have any leftover. This is the first modification on the truck, pain in the @55 when trying to get the correct radio bezel color & inset color(the dealer needed vin numbers of one that had the right bezel, plus my vin, plus his vin, plus her vin, you get the picture). :doh:
Sorry the pictures are lacking detail, when I post detailed pictures the forum site will not accept them. Stated that the picture is a larger tolerance than allowed on this site. :thppt:
Mr.Smith
Post by Mr.Smith » Fri Dec 13, 2013 7:14 pm
Received the driver TRE from Thuren Fabrication on Tuesday the 26th of November. Finished the truck that night after work, using Don's suggestions for a proper alignment. Had the truck professionally aligned the next day, everything was spot on except the toe-in was out only 20 thousandths.
Here's the truck...
Mr.Smith
Post by Mr.Smith » Fri Dec 13, 2013 7:30 pm
Here's the Thuren drag-link/tie-rod combo(heim-joint steering system for 2008.5+ "T" style steering)
Thuren lower steering stabilizer tie-rod mounting clamp
Carli/Bilstein 7100 custom tuned low mount steering stabilizer
Carli adjustable(chromoly) track bar
Carli limit straps
Carli front differential guard
Carli custom(stainless) sway bar end links(adapted from Carli torsion sway bar kit using Rod End Supply 5/8"-1/2" high-misalignment stainless spacers)...
Mr.Smith
Post by Mr.Smith » Fri Dec 13, 2013 8:49 pm
At high speeds the truck soaks up all four taking flight(whoops, bumps & jumps) no problem...handles perfectly. At low speeds the truck is noticeably stiffer, however still out performs stock by leaps & bounds. I've still some drag-link adjustment & a final re-torque to be completed & installation of the front steering dampener skid-plate. The CraveSpeed stubby aluminum antenna works quite well...when I'm not listening to satellite radio or DVD. Any questions I may have left out, or forgotten to answer...feel free to ask.
Post by 2wagons1driveway » Sun Jun 15, 2014 10:36 pm
Digging the drag link set up! How do those Carli full springs work? Soft enough to let you use all of that 2.5 kings Tavel when moving quick? How are they when you have weight in the bed?
Mr.Smith
Post by Mr.Smith » Sun Jun 15, 2014 11:19 pm
I'm using them in conjunction with Thuren shackles, so yes I'm capable of reaching the full potential of the Kings. I now need to modify the drive-line or fuel tank skid, due to slight contact. No more excessive bucking & fish-tailing @ any speeds...they are beautiful even loaded with two full size spares, chains & gear.
Post by 2wagons1driveway » Mon Jun 16, 2014 8:32 am
Mr.Smith wrote:I'm using them in conjunction with Thuren shackles, so yes I'm capable of reaching the full potential of the Kings. I now need to modify the drive-line or fuel tank skid, due to slight contact. No more excessive bucking & fish-tailing @ any speeds...they are beautiful even loaded with two full size spares, chains & gear.
Nice ya I had to notch my rear skid for the fuel tank also on full articulation my driveshaft was rubbing not a lot but just enough to make your ears bleed. I really want me some Carli full leafs now........and an axle truss lol
Mr.Smith
Post by Mr.Smith » Thu Jul 31, 2014 10:01 pm
KORE ultra soft race series bump stops...
Mr.Smith
Post by Mr.Smith » Thu Jul 31, 2014 10:06 pm
Carli custom(stainless) sway bar end links(adapted from Carli torsion sway bar kit & using Rod End Supply 5/8"-1/2" high-misalignment stainless steel spacers)...
Mr.Smith
Post by Mr.Smith » Thu Jul 31, 2014 10:18 pm
Carli reservoir rock guards(installed on both rear shock reservoirs, for additional protection)...
Post by 2wagons1driveway » Fri Aug 01, 2014 6:26 am
Looking very good!! Those kore bump stops look fancy have you squished them yet or what?? Also they look a bit taller then factory?
Mr.Smith
Post by Mr.Smith » Fri Aug 01, 2014 9:59 am
No full compression yet, I have not drove the truck hard lately. Maybe @ 1/2" taller, I can not recall.
Post by 2wagons1driveway » Fri Aug 01, 2014 10:30 am
Nice would
Be a nice option that's less expensive than boogies with a lot easy mounting....
azracer
Post by azracer » Fri Aug 01, 2014 3:37 pm
2wagons1driveway wrote:Nice would
They are said to work well and the only reason they are not used by the go fast crowd is that if you land (stuff) on one front corner or the other they pop out when side loaded with any real speed and you never know it until you hit metal on metal in the next rough section. I thought long and hard about those but just didn't want to risk it. I even contemplated drilling and putting in a screw to help prevent them from popping out but decided against that too. I went on a search for pair of DYSCO bumps and found a new pair someone had decided not to use when they went with hydro bumps.
The truck I showed you in that video that went bang and bent the axle had these on it for that very outing. One popped out then wham bent his axle on the next subsequent heavy hit. They are fine for light stuff and crawling but for what you plan I would skip saving a couple dollars and risking thousands!
