Mr.Smith 2009 Power Wagon Modifications
- Mr.Smith
I know I'll leave some out, but here is the list as I can remember...
Spray-in bedlinner(dealer Installed, so no idea who's product)
AMP Research/Mopar power running boards
Mopar 6 disc cd/navigation & dash bezel
Mopar rear entertainment DVD system
Mopar remote start system
Mopar engine block & battery heater
Mopar tailgate ez-down
Mopar locking fuel cap
Gates HD serpentine belt(green), idler pulley, tensioner & pulley
PAC audio/iphone stereo connection kit
3M limo tint all the way around
Bushwacker pocket style fender flares
Toyo Open Country M/T 35"x12.5"R17"
Jobox aluminum single lid crossover
Tekonsha P3 electronic brake control/mounting kit/harness kit
Diversi-Tech 6" aluminum adjustable drop hitch
Diversi-Tech 2"x2 5/16" double ball
CravenSpeed stubby aluminum antenna
Crown Performance 3" extended front & rear brake lines
AGM 980ca 800cca sealed battery
Valvoline full synthetic engine oil/front & rear differential oil/transfer case oil/transmission oil/power steering fluid/brake fluid since new
WeatherTech Digital Fit front & rear floor liners
Napa Neoform wiper blades
KORE ultra soft race series bump stops
Thuren drag-link/tie-rod combo(heim-joint steering system for 2008.5+ "T" style steering)
Thuren performance rear lift shackles
Thuren lower steering stabilizer tie-rod mounting clamp
Carli/King 2.5" custom tuned(stainless steel shafts) remote reservoir front shocks
Carli/King 2.5" custom tuned(stainless steel shafts) piggy back reservoir rear shocks
Carli/Bilstein 7100 custom tuned low mount steering stabilizer
Carli adjustable(chromoly) track bar
Carli 3" multi-rate coil springs
Carli/Deaver 3" full progressive leaf springs
Carli(chromoly) upper & lower control arms
Carli limit straps
Carli reservoir rock guards(installed on both rear shock reservoirs, for additional protection)
Carli front differential guard
Carli extreme duty upper & lower ball joints
Carli custom(stainless) sway bar end links(adapted from Carli torsion sway bar kit & using Rod End Supply 5/8"-1/2" high-misalignment stainless steel spacers)
Carli/Thuren zinc plated/stainless hardware & high misalignment spacers
A lot of miscellaneous Mopar replacement/service parts
I'll post pictures of each item installed.
Carli limit straps
Re: Mr.Smith 2009 Power Wagon Modifications
awaiting pictures!!!!!!!!!!!!
Definitely going to need to see pics!
That's a VERY nice list! Can't wait for pics!!!
No pics yet! This thread is worthless without pics lol
- Mr.Smith
Man...it's like chum to sharks. I'll get pictures posted...I'm up on the mountain all weekend working. I promise, when I get home I'll take current pictures & post them.
It's pretty effing mean. Lol
Mr. Smith.. You are like one big "BLUE BALL"
Post the stats, then wait for it!!! wait for it!!!!!!!! Waiting for it!!!!!!!!!!!! Still waiting.... Damn man!!!!!!!!! ;);)
- JBM Power Wagon
Hahahahahahaha!!!!gun45boat wrote:Mr. Smith.. You are like one big "BLUE BALL"
- Mr.Smith
Responsibilities of life take precedence over posting pictures...here are some to calm the tantrums.
Here's the Truck...
Here's the Truck...
- Mr.Smith
Here's the Mopar 6 disc cd/navigation & dash bezel, the truck is an SLT basically & came with a single CD/non-navigation setup...
- Mr.Smith
Here's the Mopar rear entertainment DVD system...
- Mr.Smith
Here's the Tekonsha P3 electronic brake control/mounting kit/harness kit mounted. I spliced together the supplied Mopar harness & P3 harnesses, then ran it through the back of the console using wire loom & a 3/8 rubber grommet...
- Mr.Smith
Here's PAC audio/iphone stereo connection kit connected & routed through the glovebox...
- Mr.Smith
Here's the AGM 980ca 800cca sealed battery, with the Mopar battery heater & blanket installed; this is the only picture I could show, that says AGM & the specifications...
- Mr.Smith
Powder coated front differential cover & Carli differential guard...
- Mr.Smith
Hidden front remote reservoir...
- Mr.Smith
Deaver rear leafs, piggy back reservoirs & powder coated rear differential cover...
- Mr.Smith
Here's the Toyo Open Country M/T 35"x12.5"R17" tires on stock wheels...
- Mr.Smith
Here's the Full size spare, donated from a 2006 Dodge 2500HD diesel. If you look close you'll see some WeatherTech Digital Fit front & rear floor liners on the floor waiting for cleaning...(If any of you want one for a polished full size spare let me know, I have X3 more)
- Mr.Smith
Here's the CravenSpeed stubby aluminum antenna...
- Mr.Smith
Here's the AMP Research/Mopar power running boards, if you look close you can spot a stock front brake line...
- Mr.Smith
Here's the Jobox aluminum single lid crossover...
- Mr.Smith
Here's the Diversi-Tech 6" aluminum adjustable drop hitch & Diversi-Tech 2"x2 5/16" double ball...
How does that do for reception?Mr.Smith wrote:CravenSpeen antenna...
