Here is my rock rail build hope it helps for those looking for ideas.. I used .250 plate that I welded to the frame. Than 2x2 .250 wall tubing welded to the plates with .250 gussets. For the rail I used 2x2 .250 wall with a 2" round tube .187 wall for the step. I know its overkill but once I weld those suckers on there never coming off so they have to be very strong. I would use .250 wall for the step instead of .187 because I dented my step on a rock.
I left only about a quarter inch between the rail and the pinch weld but the rail is still over an inch from the actual rocker.
Rock Rail Build
- Powerwagonmark
Rock Rail Build
2008 Dodge POWER WAGON
- chromehound
Re: Rock Rail Build
Any close up pics of where you mounted it to the frame? I'm just wanting to make sure my design is right before I go into production mode.
Thanks
Thanks
- Powerwagonmark
Re: Rock Rail Build
Sorry I got no close up ones. I'll take a few pics when I get a chance . Remember I have a long arm lift on mine so my mounting points will be different than stock. Take that into consideration if you plan on lifting your truck.
- chromehound
Re: Rock Rail Build
When ever you get some would be fine. I'm mainly worried with where vetically to put my plates or if I should do plates that are the full height of the frame since I've seen so many diffrent styles made but none actually on a PW. I'm not planning on any more height but things do change.
- Powerwagonmark
Re: Rock Rail Build
The full height of the frame is fine. Are you bolting them on or welding???
- chromehound
Re: Rock Rail Build
Bolting so if I ever screw them up, need/want to change something, re-cover them or sell the truck they can be pulled off.
