Diesel PW Build Thread
Re: Diesel PW Build Thread
Post by TwinStick » Sat Mar 17, 2018 11:43 am
AWESOME JOB !!!!!!! I love it. Function and form. Lots of light, strong enough to take an animal strike & tucked in good around the edges. What more can you ask for ? Maybe some front coils down the road if she starts sagging too much.
Post by nts007 » Sat Mar 17, 2018 9:31 pm
Thx twin!! I'll have to talk to thuren if I get sagging on his springs lol. I spent half a day chasing cows and the bumper did a excellent job at turning them round with some nudging. Some not so light bumps. Really happy with the beam pattern I was able to come up with. Low beam isn't obtrusive but high beam is a huge spread. Hard to get a good picture of it. But high beam mode gets me almost 150° width with a solid Center throw. And that's before the lightforce come on and the light bar. Now to see if it holds up to some mild off roading lol
Post by nts007 » Sun Mar 18, 2018 8:01 pm
Steering day. All new front end! Only one joint was really bad. As in it came out of its cup. And I hammered it back in. Drove the rest of the week. Replaced it with moog again. All under the lifetime warranty so it's costing me nothing. And I got 160-180k km out of the last set so no complaints. Can't justify the cost of anything else really.
Post by DamageWagon » Tue Mar 20, 2018 2:27 am
How far did you end up driving on just the hydro assist?
Post by nts007 » Tue Mar 20, 2018 11:26 pm
Little over 60miles. Little bit around the city then all the way home on the highway. I didn't realize it was completely disconnected until I got home. I thought it was just loose
Post by DamageWagon » Tue Mar 20, 2018 11:30 pm
You caught a free upgrade to full hydro!
Post by nts007 » Tue Mar 20, 2018 11:34 pm
Haha yea but not the way I expected to lol. It wandered a lot on the highway. Well slightly more than normal haha
Post by DamageWagon » Tue Mar 20, 2018 11:40 pm
Oh, oh dear, your dodge wandered on the highway! :rofl: :jawdrop: :rofl:
gun45boat
Post by gun45boat » Wed Mar 21, 2018 3:23 pm
[/quote]
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :rockon: :rockon:
Post by nts007 » Sun Apr 01, 2018 5:38 pm
First time it’s been washed since last July. Changed out the pw flares for a bushwhacker knock off. Also all that Bedliner rocker guard.....destroyed. It’s bad. Oh well. Time for a new idea
Post by TwinStick » Sun Apr 01, 2018 9:07 pm
What kind did you use on the rockers ? Mine is still holding up great......but i dont drive on gravel all the time.
I used this shit: https://www.durabakcompany.com/?_vsrefd ... nt=Durabak
VERY happy 10 years later.
Post by nts007 » Sun Apr 01, 2018 9:09 pm
I used a DuPont kit. it's ok. I'm almost convinced I'm bedlining the whole truck soon. Going to find a company that would guarantee it. Running gravel at 70 mph and tires that pick up rocks fairly easily is just destructive. The whole underside gets a sand blasting daily
Post by Colibri » Sun Apr 01, 2018 9:26 pm
I wouldn’t do the whole body, it can hold moisture in and cause massive rusting. I’ve seen it before, absolutely destroyed a Jeep tub
Post by nts007 » Sun Apr 01, 2018 11:48 pm
I've seen a few completely done. Mind you with the he way good bedliner is the whole body could deteriorate and the bedliner would bold the shape lol. But good to know thanks!
Post by TwinStick » Fri Apr 20, 2018 10:56 am
The beauty of the Dura-Bak is that it has small rubber particles in it, that cushion the stone impacts & you can put as many coats on as you want. Just follow the directions to the letter.
Post by nts007 » Sat Apr 21, 2018 11:22 am
THUREN LT LEAVES!!! Are here. Going to be installing them today or tomorrow.
Durabak works well in bedliner but as rocker guard I really don't know. Not even my exhaust Tip survives the rock rash
Post by Colibri » Sun Apr 22, 2018 3:13 pm
Well???? What’s the deal with the long travel leaves man????
Post by nts007 » Sun Apr 22, 2018 3:23 pm
You mean THESE!!! It sucks balls doing these by yourself. So heavy and awkward. But they are in. So far I’m happy. They are noticeably smoother on the small bumps. About 1/2” more height over the pw leaves. Time will tell. My 2 am 4 mike drive wasn’t enough to get a good feel for them.
Post by adeluca73 » Tue Apr 24, 2018 3:57 pm
Neal, I dig your custom ice,salt,sand,mud undercoating. Seems to form a solid protective barrier around the entire truck. :cheers:
Post by nts007 » Wed Apr 25, 2018 12:36 am
It also makes good camouflage in the fall😂 Solid barrier is a way to describe it. Probably adds a few pounds but you know.
w2dodge
Post by w2dodge » Wed Apr 25, 2018 1:41 pm
them old leaves are good knife material..
Post by nts007 » Thu Apr 26, 2018 12:23 am
As my brother has made me aware. But fret not they are to be stage one progress on the bastard wagon. Which will be making progress soon
Post by Low_Sky » Thu Apr 26, 2018 1:31 am
I forgot all about the bastard wagon. Oh boy!
Post by adeluca73 » Tue May 01, 2018 12:40 pm
5160 spring steel. Clad and Sons is offering a 200 limited run of Buck 110's in 5160 in a Drop Point blade and Black Charcoal Scales.... :cheers:
Post by TwinStick » Thu May 03, 2018 12:43 am
That is a good deal, on steel that cuts other steel !!! :rockon:
