EasyDoesIt's Build - 2018 Power Wagon "White Rhino"
Re: EasyDoesIt's Build - 2018 Power Wagon "White Rhino"
Post by olyelr » Sat Feb 09, 2019 1:27 pm
They turned out great!
Post by Reloaderguy » Sat Feb 09, 2019 2:45 pm
That's the first set of frame mounted sliders that I think look good. Well done!
Post by Colibri » Sat Feb 09, 2019 3:44 pm
Those came out really slick! Good job sir!
EasyDoesIt
Post by EasyDoesIt » Sun Feb 10, 2019 12:54 pm
Thanks guys. I'm not sure I'd do it again but I do like the way they turned out and the fact they are unique doesn't hurt. Time to put them through their paces.
I've officially ordered Thuren 1.5" lift front springs, rear track bar, and Dethloff skid (Thanks Marcus).
Stayed tuned for install details
EasyDoesIt
Post by EasyDoesIt » Sun Feb 24, 2019 9:00 pm
Installed the Thuren Rear Trackbar this afternoon, pretty straight forward after you understand how all the brackets fit in.
The first test to see if the trackbar was worth the money is on my trip to the airport in the morning, I usually get an intermittent rear shimmy at highway speeds.
Should get the front springs installed in March.
Post by DamageWagon » Mon Feb 25, 2019 1:27 am
Sweet man!!
FYI When you do the front springs don’t forget to disconnect the locker plug on the axle.
EasyDoesIt
Post by EasyDoesIt » Mon Feb 25, 2019 12:18 pm
Sweet man!!
Thanks Marcus. The truck seems to behave better at high speeds.
Good call on the locker plug.
EasyDoesIt
Post by EasyDoesIt » Fri Apr 12, 2019 1:15 pm
I installed the front Thuren springs a few weeks back and the difference in high speed offroad is night and day. I can only imagine how much better it would be with some 2.5s. Maybe someday.
The skid plate arrived a couple days ago and I'll get it mounted in the next few days. The quality of the skid, hardware, packaging and instructions are top notch! I appreciate the instructions list the tools needed and are printed on a heavier paper. Nice work Marcus.
A couple pics from a camping/offroad trip to Whitney Pockets Nevada
The Cistern
https://goo.gl/maps/Lbq5C5HSScA2
Devils Throat
https://goo.gl/maps/mLHEZZGzFX62
Little Finland
https://goo.gl/maps/93DBNfLtEV62
The attachment IMG_20190322_215845.jpg is no longer available
Post by DamageWagon » Fri Apr 12, 2019 2:10 pm
Awesome dude I’m glad you like the skid plate, I appreciate the feedback!
richxd87
Re: 2018 Power Wagon, White Rhino
Post by richxd87 » Fri Apr 12, 2019 3:23 pm
EasyDoesIt wrote:
Mon Feb 19, 2018 2:30 pm
Progress was slow but we did finish the bulk of the project. Will finish the 1-3/4" tube step in the next couple months.
Going to paint them with some black heavy equipment paint and get them mounted for pre-moab testing.
Milling the 1/2" holes in the 2"x1/2" frame plates
Thanks for sharing! Any particular tips/tricks on the mounting plates and legs or is it all pretty straight forward?
Richard
EasyDoesIt
Post by EasyDoesIt » Fri Apr 12, 2019 6:09 pm
Richard
Its not really straight forward and If I had to do it over again, I wouldn't, I'd just get the white knuckles. Its a challenge but its rewarding to have the exact sliders you want. Plan for it to take a full two days with the help of a friend and the right tools (welder, band saw, bender, grinder, impact, etc etc). The only thing I'd do differently would be to make the support bars an inch longer.
Measure 3 times, cut or bend once.
If you need any detailed pics/measurements, drop me a PM with your number and I can text ya anything you need.
Steve
