PWJouster's Build - 2018 Power Wagon "TrailWhale"
Re: PWJouster's Build - 2018 Power Wagon "TrailWhale"
Post by Reloaderguy » Tue Nov 06, 2018 9:34 am
PWJouster wrote:
Tue Nov 06, 2018 9:27 am
Updated the planned and completed .
Thuren PW bumper is ordered.
i will get a black Warn Fairlead and Yellow Baja pods for the Winglet Fog holes, and two baja spot pods next to winch, powered by a switch.
i would like the yellow fogs on with lowbeams with oem switch and spots activated with highs
When you pull off your bumper save the fog light harness. You can run 40A cubes safely on the wiring.
RPS1030
Post by RPS1030 » Tue Nov 06, 2018 9:47 am
FYI, the old Squadron Sports were too bright for in-traffic use and the current upgraded Sports are nearly Pro level output and will be way to bright for traffic use.
But SAE-Rated Fogs are coming in 2019.
Rodeoflyer
Post by Rodeoflyer » Tue Nov 06, 2018 10:10 am
I’m running four of these in the fog locations.
RIGID INDUSTRIES D2 HIGH & LOW LED LIGHTS - 50231H
On low setting I’ve never had anyone complain or high beam me on road.
https://youtu.be/N5rQ4k8vc6s
The bar is a diode dynamics ss18 18’’ combo bar on the bumper for spot
PWJouster
Post by PWJouster » Tue Nov 06, 2018 11:24 am
D-Series PRO
D-SERIES PRO
SKU: 202113
Number of Lights 2 Beam Category FLOOD Housing Color Black Mount Type SURFACE MOUNT Light Color White
Edit
$199.99
1
$199.99 Remove
D-Series PRO
D-SERIES PRO
SKU: 90151
Number of Lights 2 Beam Category DIFFUSED Housing Color Black Mount Type SURFACE MOUNT Light Color Amber
Edit
$229.99
1
$229.99 Remove
Adapt
ADAPT
SKU: 220413
Common Size 20"
Edit
$1,399.99
1
$1,399.99 Remove
E-Series Pro
E-SERIES PRO
SKU: 122313
Beam Category SPOT DRIVING COMBO Common Size 20" Housing Color Black Light Color White
Edit
$849.99
1
$849.99 Remove
adapt or not to adapt..
17 Method NV-Toyo RT 35
SPOD
Rodeoflyer
Post by Rodeoflyer » Tue Nov 06, 2018 11:51 am
I don't get the whole ADAPT thing.. however if you want to have that kind of control...degrees of light are degrees of light and lumens dependent mainly on reflector and LED type. You want a flood/spot/superspot (for 100mph driving offroad :D ).
The D2's provide massive flood and driving. Another small 12''-18'' spot/superspot will provide range.
I don't think diffused is necessary in a front facing light, maybe for rears. I'd only go with the ADAPT single if that was my ONLY front facing lightbar.
PWJouster
Post by PWJouster » Tue Nov 06, 2018 11:59 am
neither did i until i saw them in action just the other day.
they are sick, and i plan on using the Amber color as a daytime running light.
either i need a specific split of flood vs spot lights, or i can rely on the adapt for spot lighting and flooding.
i probably wont go for it, but its a cool product.
SPOD
PWJouster
Post by PWJouster » Tue Nov 06, 2018 12:02 pm
you did edit this post retroactively no? lol
exactly.
my thought was
yellow fog lights as daytime markers,
spot beam pods to assist high beam at night on road,
and a 20 inch bar in the new powerwagon grill mustache with driving/spot combo.
ill pull out the lower plastic grill applique and recess a 20 inch bar in the grill, mounted on the thuren bumper
SPOD
Rodeoflyer
Post by Rodeoflyer » Tue Nov 06, 2018 12:03 pm
I have amber covers on two of my D2's. I guess it depends on conditions but that's all the amber I'd need. IO have separate lo/high switches for both sets of D2's and another set of switches for the main LED bar. Yeah, I'm at work so I'm editing and working lol. I think I've done exactly what you're thinking about.
Post by DamageWagon » Tue Nov 06, 2018 12:37 pm
Let me know if you need any BD stuff. I can’t help with Rigid unless you want what’s on my shelf
PWJouster
Post by PWJouster » Wed Nov 07, 2018 4:44 pm
i would like to see SAE DOT compliant BD in amber fog pod so i can match it with squadron driving/spot pods...
otherwise,
right now im at Rigid SAE D2 in amber for fog/daytimes
two rigid d2 Flood/driving
and one driving/spot Baja design onx6 bar
SPOD
Post by Colibri » Wed Nov 07, 2018 5:20 pm
I’m almost exclusively a user of baja designs, with the one exception being the rigid sae compliant fogs. They work really well for on road, never had any problems irritating other drivers with them. Excellent beam cutoff and spread.
They aren’t nearly enough for offroad, but sounds like you got that covered with the other stuff!
Can’t wait to see it all mounted up sir, it’s going to be a lot of light
PWJouster
Post by PWJouster » Tue Jan 15, 2019 10:31 am
FINALLY!!
evo sway disconnect is insane...and to be honest, i now know i will rarely have my swaybar connected. disconnected with this thuren suspension is ideal.
ARB and 2.5 gallon mounted with the compressor and air chuck access in Ram box... this is great
Kill switch and Locker bypasses installed and work. not tested offroad yet.
thuren bumper is a beast and the lights were mounted perfectly.
SPOD
Post by Colibri » Tue Jan 15, 2019 4:13 pm
That looks absolutely fantastic!! Good work sir, nice clean install on the air too!
Post by olyelr » Tue Jan 15, 2019 7:42 pm
:rockon:
Im digin the compressor setup for sure! I would love to see a little more on that install.
PWJouster
Post by PWJouster » Wed Jan 16, 2019 9:42 am
i gave Brandons truck and auto the placement and build direction guidance and they made some of their own calls.
the rambox unit comes out all together, and a bracket plate gets placed on the opposite site of the plastic box, bolt through and as solid as it needs to be. the quick connect coupler has a big washer on the opposite side, and again, this plastic is actually very stiff and sturdy.
arb twin routed to 2.5 gallon tank where the spare used to be, and its routed back to the coupler for access in the rambox, which i will fill with all the air tools and whips.
SPOD
PWJouster
Post by PWJouster » Wed Jan 16, 2019 9:44 am
that twin is compact for sure.... ive seen them in the under floor compartments of our trucks.... wow
SPOD
PWJouster
Post by PWJouster » Wed Jan 16, 2019 9:46 am
all i have left as it relates to long term ownership
-truss
-balljoints
ill do these once i notice steering degradation, which is about now at 18k miles
white knuckle sliders
high clearance chop of the rear end with a 3gen tube style bumper bar whenever someone figures that out.
8 speed and supercharger right?
SPOD
PWJouster
Post by PWJouster » Wed Jan 16, 2019 9:48 am
i hate the fact they didnt actually screw up the powerwagon for the next gen. i like alot of those improvements, but i have to say my 18 looks burly and tough while all these new trucks look to modern and crisp
SPOD
Post by OffroadTreks » Wed Jan 16, 2019 12:39 pm
It's tempting, very tempting. But just not enough to get me to accept new truck prices. I really wanted those improvements in the back seat area. We'll see what 22 brings.
Post by RustyPW » Wed Jan 16, 2019 7:31 pm
All I want is the engine and tranny out of the new PW. That 8 speed auto. :drool:
My build thread. :rockon: :cash: :cash:
viewtopic.php?f=13&t=2826
PWJouster
Post by PWJouster » Thu Jan 17, 2019 8:50 am
the 6.4 is the end all option for our powerwagons... until they start boosting small v8s
that 8 speed should be stout, clean shifting, and MPG boosting, but the low end gearing i guaranty they get wrong for the sake of reliability.
SPOD
PWJouster
Post by PWJouster » Thu Jan 17, 2019 9:05 am
EVO ON DEMAND AIR SWAYBAR DISCONNECT.
WOW
Findings were relatively expected
I have never actually removed links to test no stock swaybar at full speeds. If i had, i may have removed the swaybar all together as long as i wasnt towing. the Thuren suspension is absolutely ideal! As it relates to body control and comfort, to be honest, NO swaybar makes thuren tuned kings shine brightest.
The truck is a dream with the swaybar discod, flying down the highway or gravel roads. body control is epic and at no time does the body sway become intrusive. Couple that with an ABS kill switch and 2HI rear locker, and its the truck youve always dreamed of owning.
^that is for the person who drives moderately on road and doesnt pretend to have a trophy truck or sports car
TRUTH
i need a swaybar.
there are times when i do drive entirely way to aggressive on road, testing the limits of the 35 Toyos and thuren tuned suspension. Stock swaybar and no swaybar on entrance/exit ramps, taking any long sweeping turn, 90°turns or any kind of change of direction, is a huge difference at speed.
Ill probably hit the Spod switch every time in jump in the truck, as it maximized comfort for the daily.
When i know ill be racing or actin a fool on road surface, ill keep swaybar engaged for maximum control and stability.
SPOD
Post by Colibri » Thu Jan 17, 2019 10:27 am
One of the best things I ever did was ditch the stock swaybar in favor of a torsion bar. Biggest single improvement to my truck. At least on my gen power wagon, torsion bar was way better than no bar or running disconnected, and no bar was way better than stock.
The tuned suspension works wonders in body control, but when you add the torsion bar in it really does enhance traction and control.
I have my rear bypasses set very soft for the first half of travel and in combination with the torsion bar up front it allows the body to rock back on the rear suspension under acceleration to maximize hookup traction and also lets the body lean controllably around a fast corner to weight the outside tire and give maximum bite in a turn. It takes a little getting used to but it works fantastically
That evo disconnect is super slick though.
PWJouster
Post by PWJouster » Thu Jan 17, 2019 10:33 am
i assume over uneven, ungraded, or off camber highway runs , which is everywhere in south florida as everything is under construction, and i daily this at over 16k miles a year, that no swaybar can provide maximum Comfort on long stretches of road. and it surely does. it numbs out almost all the road imperfections when discoed, caddi esq
SPOD
PWJouster
Post by PWJouster » Thu Jan 17, 2019 10:41 am
SPOD
great product and does exactly what its designed to do.
easy install and easy maintenance.
Bantam is small!!!! and very high quality
HD touchscreen is ideal! and such a small footprint for 4 switches.
@trailwhalePowerwagon on instagram for some photos.
one huge gripe.
the switch panel has full power at all times with the standard setup.
i am way to forgetful. already got a call last night for my fog lights being left on, and more discreetly swaybar still discoed(unsure of the power draw with the arb solenoid left open?)
only switches 1 and 2 can be activated by keyed ignition source,luckily, i only ever plan to have amber fogs and swaybar discoed on the regular.
but if i leave any other switch on, down goes the battery.
anyone have any simple and reliable alternatives to power the entire spod block only when keyed ignition is on?
SPOD
