on board air
verdesardog
on board air
Post by verdesardog » Sun Feb 17, 2013 12:32 pm
I just ordered this from amazon for about $420.
VIAIR 200 PSI Ultra Duty Onboard Air System
I need it for the engine brake I 'm gong to install for my diesel. So now I will also have air for airing up tires and the rear airbags, I guess I have to get an air horn next LOL
I think I'll keep the Q50 just because it's still new in the box. Used only once to air up after an off road trip.
pdavey
Re: on board air
Post by pdavey » Sun Feb 17, 2013 2:28 pm
Looks like a nice kit. Would love to see pics of the install. I am planning on doing something similar.
Sent from my DROID DNA
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
verdesardog
Re: on board air
Post by verdesardog » Fri Feb 22, 2013 5:31 pm
ok, now where's a good place to mount the compressor and air tank? I have no room in front of my radiator like you PW owners....
Dawizman
Re: on board air
Post by Dawizman » Fri Feb 22, 2013 9:54 pm
Myoung84 built some brackets to mount everything up on the passenger side frame rail. Here is the thread over on dt:
http://www.dodgetalk.com/forums/showthread.php?t=363681
verdesardog
Re: on board air
Post by verdesardog » Fri Feb 22, 2013 11:33 pm
thanks for the link but I think there must be a way to do it without drilling into the frame. It's been too wintery here to even look under the truck...
verdesardog
Re: on board air
Post by verdesardog » Sun Mar 03, 2013 3:36 pm
OK, so I made a stainless steel splash gaurd for the compressor and brackets to hang from the frame rails. Under the drivers side, not plumbed or wired yet .....
I have a different drain valve on the way but will probably make a skid plate to protect it:
The compressor doesn't hang as low as it looks in the previous pics but if I was going to rock crawl I would have put everything in the tool box in the front of the bed.
Dawizman
Re: on board air
Post by Dawizman » Sun Mar 03, 2013 9:37 pm
Looks pretty good! Wish I had the funds to do some more mods like this.
Fireman78
Re: on board air
Post by Fireman78 » Fri May 24, 2013 12:22 am
Same kit I have. No problems at all so far. I like where you mounted the tank. I went the easy route and put it in my truck bed under the truck box.
