on board air
- verdesardog
on board air
I just ordered this from amazon for about $420.
VIAIR 200 PSI Ultra Duty Onboard Air System
I need it for the engine brake I 'm gong to install for my diesel. So now I will also have air for airing up tires and the rear airbags, I guess I have to get an air horn next LOL
I think I'll keep the Q50 just because it's still new in the box. Used only once to air up after an off road trip.
Re: on board air
Looks like a nice kit. Would love to see pics of the install. I am planning on doing something similar.
Sent from my DROID DNA
Performance Mods:
Performance Mods:
- verdesardog
Re: on board air
ok, now where's a good place to mount the compressor and air tank? I have no room in front of my radiator like you PW owners....
Re: on board air
Myoung84 built some brackets to mount everything up on the passenger side frame rail. Here is the thread over on dt:
http://www.dodgetalk.com/forums/showthread.php?t=363681
- verdesardog
Re: on board air
thanks for the link but I think there must be a way to do it without drilling into the frame. It's been too wintery here to even look under the truck...
- verdesardog
Re: on board air
OK, so I made a stainless steel splash gaurd for the compressor and brackets to hang from the frame rails. Under the drivers side, not plumbed or wired yet .....
I have a different drain valve on the way but will probably make a skid plate to protect it: The compressor doesn't hang as low as it looks in the previous pics but if I was going to rock crawl I would have put everything in the tool box in the front of the bed.
Re: on board air
Looks pretty good! Wish I had the funds to do some more mods like this.
Re: on board air
Same kit I have. No problems at all so far. I like where you mounted the tank. I went the easy route and put it in my truck bed under the truck box.
