New lightweight fast set up tent...
Post by TwinStick » Wed Dec 27, 2017 6:00 pm
Just picked up one of these: http://www.cabelas.com/product/camping/ ... s?slotId=9
Looking forward to testing it out this year. Even though it has 1500mm coating on rainfly & 3000mm on the floor/tub, I am still going to coat it with some of this stuff: https://www.sunnysports.com/p-nkwtgs/ni ... adType^PLA
I used it on my last small tent & it was still rocking strong after 25 yrs. This new tent is a little bigger than the 2 person I had. Fast set up & take down too. Our 8 person is great if you are gonna be there a week or more & tons of room. So, now i am covered (no pun intended) for long stays, short stays or while using the camper if the kids show up---they can tent it. I plan on doing some solo trips as well & the small tent would be perfect.
