HF 301 piece tool kit
Post by TwinStick » Tue May 17, 2016 12:07 am
So, I finally picked one up on super sale for $160. I gotta say, I am impressed. There is a few guys at work that swear by them & not at them. I got it for a general tool kit to throw in the camper/truck while traveling, so I don't have to keep switching stuff from garage to truck & back again. If you need something like that, check these out. :rockon:
