Ham radio and power wagons
Post by Colibri » Sat Jan 02, 2016 4:49 pm
About to install my first mobile rig in the power wagon, a kenwood tm v-71a dual band 2m/70cm with a comet ca-2x4srnmo antenna. Any other hams on here? Any tips or advice is appreciated guys. Should I bond the bed and exhaust for 2m or is that more for high freq use?
Cactus Red
Re: Ham radio and power wagons
Post by Cactus Red » Sat Jan 02, 2016 7:52 pm
I've used two Yaesu radios, an FT-7900 70CM/2M dual band and FT-2900 2M ( currently in the truck). Both were used with multiple antennas - fender mount and hard mounted thru the roof, and the bed/exhaust were bonded. I have a bad RPM based buzz on reception, output is fine. I haven't been able to solve it.
My buddy BX has no problems in his '09, so I believe it's something weird with my truck.
As far as range and clarity of reception go, the 5/8 wave roof mount is awesome. I've connected into repeaters over 100 miles away (from near Williams AZ to Aguila AZ) when conditions are good.
Mule
Post by Mule » Mon Jan 04, 2016 2:51 pm
Brains under the back seat
Ext. speaker and mic coupler
Ebay suction-cup bracket, yanked the suction cup out, filled the cup with epoxy, and VHB-taped the sucker on...
Cleans up all nice n' stuff...
Glass-mount dual-band on the rear window. Works breddy gud.
Digital doesn't care as much, so an HT's generally adequate. Wouldn't mind having an XPR5550 wth HCH in there, but ... :cash:
Always used HT's more anyways, since I'd rather be on the moto or snowmobile than camped out in a truck. 8-)
chrisjameswagner
Post by chrisjameswagner » Tue Jan 05, 2016 2:03 pm
Here's my set up.
