New (soon to be offroad) Trailer..Stage 2..Part 2 (5/15/17)
TonkaPW
Re: New (soon to be offroad) Trailer
Post by TonkaPW » Wed Apr 30, 2014 12:09 am
dogcar3 wrote:
TonkaPW wrote:This is an awesome build project. I love how you used the existing gas openings for the electric and water. The only thing I would change out would be the ball hitch for a pintle hitch. I have seen ball hitches pop loose in extreme conditions but I have never lost anything with a pintle hitch. :idea:
I do have a concern about the ball hitch. I would really like to get something like this:
https://locknroll.com/
A pintle hitch that swivels would give you all the articulation you would ever want with twice the straight. Looking at the links provided I would be concerned about breaking the hitch if you find yourself in a situation that causes the trailer to get bound up. With the pintle I have seen guys bend things but never lost the trailer.
White Knuckle Rock rails
2" lift
35" Duratracks
Thuren control arms
dogcar3
Post by dogcar3 » Tue May 20, 2014 3:50 pm
OK, finally got back to taking some pictures and posting an update. I am more or less done ("done") with the trailer. Just a few small items that have come up as nice-to-haves after its first limited use. Like a bottle opener mounted near the fridge. Still have to save the funds for a small propane fire pit and a small generator (both from Costco, might be getting them this week). Also waiting on a double propane tank mount/hold down from Amazon.
Here is where it sits right now.
New locking hitch, power connector, new jack.
Inside the front tool box. Has two propane tanks, some tarps, a couple of the 1lb tanks, my tire chains, a 4 gallon gas can (for the 2k watt generator that I will have, should be a solid 5 days worth of normal use to charge battery and what not), and some leveling blocks. The fire pit will fill up the empty space perfectly.
Front box with new spare tire carrier. Can also be used as an umbrella mount (umbrella slides into the vertical tube).
Front left compartment. Has the battery, AC charger, solar charger, fuse panel, switch panel and gauges, extension cord, fire extinguisher, wheel chocks and some misc stuff. The lighting is powered up by the lighted switch, then is turned on by a door switch when each door is open. This switch also powers the three 12v outlets onboard.
Switch panel. From left to right: under lighting, solar charger, fridge, water pump, cabinet lighting/12v outlets, tent power, spare, gauge turn on switch.
Power inlets. AC plug with my solar panel connectors on top.
View of the under lighting (rock lights). Will turn on when I turn on my truck rock lighting, or manually turned on from the switch panel.
Middle left compartment. Houses the inverter, jump starter, radio, a 12v fan, some misc items in the bags, and a 12v vacuum.
Water inlet/outlet. I have a misting system that hooks up to the hose outlet for our pop up canopy.
Water tank and view of the piping/wiring/gas hose. 21 gallon tank.
Left rear compartment. Sink, hose, misting stuff, first aid, hand sanitizer etc...I have a 5 gallon bucket that gets placed under the trailer for the sink to drain into.
View into the rear cargo area. Yes, that is an A/C unit. Will run off the generator (or limited use off the inverter). It mounts up to the tent.
Inside the rear compartment with the slide out. There is room for storage behind the slide. I also have my solar panel and a table in here, next to the water heater and fire extinguisher. In the front I have a propane heater, some more folding tables, misc camp items, some more tarps (heavy canvas).
Easy access to the fridge.
Umbrella holders. They work out quite nicely. Can also see the back up lights.
RIght rear compartment. This is the pantry. Already has some left overs from the BBQ this weekend. Used the trailer and it worked great.
Middle right compartment. Houses the stove (has a propane hookup) and commonly used kitchen items.
The picture for this one got corrupted on my phone.
Front right compartment. Kitchen storage space.
Very happy with the way things turned out. Just need to test things out some more to make sure it will hold up then start using it.
2012 Beast.
Mr.Smith
Post by Mr.Smith » Tue May 20, 2014 5:04 pm
This is great! Well done Sir!
Post by 05PWrockcrawler » Tue May 20, 2014 6:21 pm
Very sweet!
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Tue May 20, 2014 6:27 pm
Great job!
bajaben48
Post by bajaben48 » Tue May 20, 2014 10:47 pm
:cheers: :rockon: :notworthy: :o
just wow. that is all I can say. you need to build and sell these guys. I bet there is a huge market out there for trailers of this kind.
quick question. where did you get your water tank. I have a leak in my rv water tank and its beyond repair.
Ben
Us Army EOD
dogcar3
Post by dogcar3 » Wed May 21, 2014 8:32 am
Thanks for the comments everybody.
Here is the water tank I ordered: http://www.amazon.com/gp/product/B007MS ... UTF8&psc=1
I honestly think I would get burned out if I did my hobby for a job. This trailer has certainly been a conversation starter already, just wait until I actually take it camping.
2012 Beast.
bajaben48
Post by bajaben48 » Wed May 21, 2014 9:35 am
I know what you mean about doing a hobby as a job. I love welding and metal work but if I did it as a job....not fun any more
sent from a deep hole know only in fabels
Ben
Us Army EOD
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Wed May 21, 2014 2:54 pm
dogcar3 wrote:Thanks for the comments everybody.
That's why I stopped working for Mazda NAO. I was getting burned out and automotive just wasn't fun anymore. I just use my education for fun now and I'm much happier.
SheepdogOutdoorsman
Post by SheepdogOutdoorsman » Wed May 21, 2014 2:55 pm
dogcar3
Post by dogcar3 » Tue May 27, 2014 8:46 am
The latest addition:
2012 Beast.
Post by adeluca73 » Thu Jun 19, 2014 1:28 am
Wow. I'm always a lot amazed, deeply impressed, and a little ashamed by all of the really talented folks on this site. I have a lot of personal skills in desperate need of improvement. :jawdrop:
Post by 05PWrockcrawler » Thu Jun 19, 2014 4:52 pm
Sweet
Throttle 8
Post by Throttle 8 » Thu Jun 19, 2014 6:51 pm
Your setup is miles ahead of some of the "professional" ones I have seen! I think you could definately turn this into a money making venture! I would definately buy yours over any of the others that I have seen out there. :rockon: :notworthy: The only thing I would add would be a swivel hitch for those of use who tend to make there own trails when moose hunting---lol.
TonkaPW
Post by TonkaPW » Thu Jun 19, 2014 11:39 pm
Just curious, but how much do you think it weighs fully loaded and ready for an adventure?
2" lift
35" Duratracks
Thuren control arms
dogcar3
Post by dogcar3 » Fri Jun 20, 2014 8:27 am
A swivel hitch of some sort is definitely in the plan, probably won't happen until after this season, we got too much stuff going on for the down time.
I have been really wanting to weigh it, but there are only two scales that I know of around here. One at the metal recycle place, and one at the sand/gravel pit. I may be making a trip to the recycle place here soon to remove some scrap.
2012 Beast.
Throttle 8
Post by Throttle 8 » Fri Jun 20, 2014 11:59 am
I see a contest-----predict the final weight!
My guess 3300 lbs fully loaded.
Post by cruz » Sat Jun 21, 2014 12:25 am
bajaben48 wrote:quick question. where did you get your water tank. I have a leak in my rv water tank and its beyond repair.
These guys have made a lot of custom water tanks for vintage Airstream restorations...
http://www.all-rite.com/custom-holding- ... b6ed851281
fyrfytr704
Post by fyrfytr704 » Sun Jul 06, 2014 11:42 pm
X2 on the weight question. That thing looks awesome and definitely sets you up for being comfortable and hosting a hell of a party wherever you stop! My only worry would be towing something that heavy up a trail with the ball hitch. Those things aren't meant to vertically articulate much, especially with a good amount of weight on them.
I'll have to take some pictures of my setup and post em, but I definitely tend to find a spot to camp, drop it and then go wheelin.
dogcar3
Post by dogcar3 » Sat Jul 26, 2014 1:55 pm
Results are in, fully loaded it sits right at 4000 lbs
2012 Beast.
fyrfytr704
Post by fyrfytr704 » Sat Jul 26, 2014 3:26 pm
Wow. That's not too bad. It's a lot like towing a Jeep on a trailer. :)
Post by TwinStick » Mon Feb 02, 2015 8:23 pm
4000 lbs is not that much for our trucks at all..............as long as you ain't running the Rubicon Trail. Just fine for moderate wheeling & camping.
GREAT JOB !!! :rockon:
dogcar3
Post by dogcar3 » Mon Feb 02, 2015 8:57 pm
Thanks. We have been talking about the Magruder trail in Idaho this summer. Among other things. Definitly not an extreme trailer. But also not extreme price. I would like some bigger tires and an off road hitch. But it has worked just fine as-is so it is hard to justify the money.
2012 Beast.
verdesardog
Post by verdesardog » Tue Feb 03, 2015 10:10 am
dogcar3 wrote:Results are in, fully loaded it sits right at 4000 lbs
WOW! that must be a lot of gear, 4,000 lbs.
Sometimes I think I would like a service bed on my truck but then realize that if I had all that storage space it would be filled with stuff.
dogcar3
Post by dogcar3 » Tue Feb 03, 2015 2:48 pm
Definitely a lot of luxuries to get the better half to go. But better in the trailer than the truck. We drop the trailer at camp then go have fun in the truck.
2012 Beast.
