Board index Miscellaneous Gadgets, Gizmos and Gear
Re: New (soon to be offroad) Trailer
Postby 15wbpw » Tue Feb 10, 2015 5:00 pm
Pretty sure this is the same box/bed we've got on our work truck. I wish ours had half the amenities of yours! Great work.
15wbpw
Postby TwinStick » Sat Apr 18, 2015 9:14 pm
verdesardog wrote:
dogcar3 wrote:Results are in, fully loaded it sits right at 4000 lbs
WOW! that must be a lot of gear, 4,000 lbs.
Sometimes I think I would like a service bed on my truck but then realize that if I had all that storage space it would be filled with stuff.
Well, there is: "Minimalist backpacking & camping", "Roughing it" camping, then there is "regular" camping, then there is "glamping", then there is "luxo-glamping". Pic the poison that you can afford & are comfortable doing.
:lol:
minimalist: https://www.google.com/search?q=pics+of ... B480%3B322
roughing it: https://www.google.com/search?q=pics+of ... B600%3B450
regular camping: https://www.google.com/search?q=pics+of ... B576%3B360
glamping: https://www.google.com/search?q=pics+of ... B648%3B432
luxo-glamping: https://www.google.com/search?q=pics+of ... 1300%3B957 ----Is this Rusty's ? :lol:
Postby dogcar3 » Sun Apr 19, 2015 10:30 am
I had my fair share of minimalist and roughing through Scouts. The trailer suits my current wants right now and can go most places I want to take my truck. Im sure I will want to get a real trailer when I get older.
2012 Beast.
dogcar3
Postby TonkaPW » Sun Apr 19, 2015 12:15 pm
Any pictures with it set up and the tent open? What type of RTT do you have mounted on it?
White Knuckle Rock rails
2" lift
35" Duratracks
Thuren control arms
TonkaPW
Postby dogcar3 » Sun Apr 19, 2015 3:29 pm
These are from three weeks ago. Friend has a Frontier and a trailer he won from a local off road shop. My tent is from tentsonarack.com (no longer in business). his is a CVT.
2012 Beast.
dogcar3
Re: New (soon to be offroad) Trailer....Stage 2
Postby dogcar3 » Tue Aug 02, 2016 8:12 pm
Hi everybody. Been working on my trailer again. I have replaced the suspension with something better suited for off road. It previously had the standard short trailer springs that were really stiff and not really any travel. The new stuff seems perfectly balanced for the trailer and weight. It is Chevy 1 ton springs with the bottom 3 leaves removed and some 5100s for a Chevy 1 ton as well. I used the bump stops from my truck since I now have air bags. The bump stops were not installed yet when this picture was taken.
I have also extended the bed slide to the front of the bed and narrowed it to allow easier access to my solar panel and tables on the side. Plus removed the vice, cut off some bracing that did not need to be on there, and some other minor improvements that align better with how we use the trailer.
I am currently looking for some bigger wheels and tires. Then will be a Foxwing awning and an off road hitch.
2012 Beast.
dogcar3
Postby Colibri » Tue Aug 02, 2016 8:54 pm
This trailer is fantastic sir, I don't know how I missed this build until now. Really great work and thoughtful planning. :rockon:
Postby scoutermike » Thu Aug 04, 2016 8:02 am
Love your trailer. I am always on the lookout but still haven't found one.
scoutermike
Previous
Return to Gadgets, Gizmos and Gear
Who is online
Users browsing this forum: No registered users and 2 guests
